跳转到主内容
Disconnecting Microphone from Logitech Pro 9000 Motherboard
你所需要的
  1. Disconnecting Microphone from Logitech Pro 9000 Motherboard, Front and Back Cover: 步骤 1 中的图像 1,2 Disconnecting Microphone from Logitech Pro 9000 Motherboard, Front and Back Cover: 步骤 1 中的图像 2,2
    • Remove the two 8 mm Phillips #0 screws on the back cover.
    • The motherboard connects the two covers together. DO NOT separate the two yet.
    • There is a button that loosens as the Phillips screws are removed. Don't be alarmed if it falls out.
  2. Disconnecting Microphone from Logitech Pro 9000 Motherboard: 步骤 2 中的图像 1,2 Disconnecting Microphone from Logitech Pro 9000 Motherboard: 步骤 2 中的图像 2,2
    • Remove the four 6mm Phillips #0 screws connecting the motherboard and front cover.
    • DO NOT detach the wire connecting the motherboard to the front cover.
  3. Disconnecting Microphone from Logitech Pro 9000 Motherboard, Microphone Connection: 步骤 3 中的图像 1,2 Disconnecting Microphone from Logitech Pro 9000 Motherboard, Microphone Connection: 步骤 3 中的图像 2,2
    • Grasp the white wire connector between the tabs and the socket.
    • Wiggle the connector back and forth to remove the front cover from the motherboard.
结论
团队
Cal Poly, Team 12-34, Amido Spring 2013 Cal Poly, Team 12-34, Amido Spring 2013 的会员
CPSU-AMIDO-S13S12G34
4 名成员
创作了16篇指南
1指南评论
This guide doesn’t show a motherboard and is a copy of this other guide (for a webcam):
Logitech Webcam Pro 9000 Microphone Replacement
Maximilian Cohan - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 17
总计 1,973
