跳转到主内容
Disassembly of Sony BDP-BX18 Blu-ray player
你所需要的
  1. Disassembly of Sony BDP-BX18 Blu-ray player, Blu-ray player: 步骤 1 中的图像 1,1
    • Remove the face plate by depressing the small plastic tab
    • *NOTE: eject disk tray first before dis-assembly to gain access.
  2. Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 2 中的图像 1,1
    • Release front 4 tabs in order to slide main cover forward.
    • *NOTE: slide only a few mils forwards before next step.
  3. Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 3 中的图像 1,1
    • Release tabs on both left and right sides of unit while maintaining forward pressure to slide cover off.
    • *NOTE: The arrows depict where the tabs are located.
  4. Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 4 中的图像 1,1
    • After cover removal, you should now have access to the internal components.
    • We will begin removing the power supply. Compress the center clip and open plastic shield.
  5. Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 5 中的图像 1,1
    • Release clip to remove 6 pin power cable.
  6. Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 6 中的图像 1,1
    • Unscrew two mounting screw for power supply. Slide forward and pull out for removal.
  7. Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 7 中的图像 1,1
    • This should be your current progress thus far.
  8. Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 8 中的图像 1,1
    • Release tab to remove plastic power supply shield.
  9. Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 9 中的图像 1,2 Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 9 中的图像 2,2
    • Remove the three screws.
    • Now depress metal tab to fully remove heat sink clamp.
  10. Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 10 中的图像 1,2 Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 10 中的图像 2,2
    • Pull on indicated ribbon cable to begin removal of front display.
    • Now remove single screw to remove front display panel.
  11. Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 11 中的图像 1,1
    • This should be you current dis-assembly progress thus far.
  12. Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 12 中的图像 1,2 Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 12 中的图像 2,2
    • Next, remove all three ribbon cables attached to optical disc drive.
    • *NOTE: largest ribbon cable has small secure clamp, be sure to release it before pulling.
    • Now unscrew both mounting screw for optical disc drive for complete removal.
  13. Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 13 中的图像 1,1
    • To completely remove the main board, locate screws on back of unit. Unscrew these 2 screws and then slide main board out.
  14. Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 14 中的图像 1,1
    • You should now be completely dis-assembled. For further dis-assembly of the optical disc drive, continue to step 15.
  15. Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 15 中的图像 1,3 Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 15 中的图像 2,3 Disassembly of Sony BDP-BX18 Blu-ray player: 步骤 15 中的图像 3,3
    • First remove metal shroud exposing tabs.
    • Peel back security tape and release all 4 tabs (2 on each side) for removal of top cover.
    • Now the internal components of the optical disc drive are now exposed.
结论
6等其他人完成本指南。
TEAM 7
于04/01/13注册
335 声望
撰写一个指南
7条评论
Hi! I have just a quick question! The front display panel of my Sony Blu Ray player had broken! The small board with the USB mounted onto it, remote sensor and buttons! What is the name of this board? I was looking to order a replacement
earlovann - 回复
Nice info. Need to know how to get replacement bluray player. Any ideas? Do not want to buy new TV yet.
Keith - 回复
now I know I'm missing lots of parts...lol
Tina Marie - 回复
Thanks! the hardest part was getting the tray out.
Blake Horsfall - 回复
Cannon proceed past 3, I dont understand how you are supposed to release the tabs and press forward, I only have two hands. The tabs click back in place immediately and I don't have any place to get a grip of to remove the plate
Sira Q - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 43
总计 17,165
