跳转到主内容
Disassembling the Nokia 6300
你所需要的
  1. Disassembling the Nokia 6300, Rear Cover: 步骤 1 中的图像 1,1
    • Take off the back cover by pushing it down and sliding it backwards.
  2. Disassembling the Nokia 6300: 步骤 2 中的图像 1,2 Disassembling the Nokia 6300: 步骤 2 中的图像 2,2
    • Take out the battery, SIM card, and MicroSD card.
    • Unscrew the two T6 Torx screws.
  3. Disassembling the Nokia 6300: 步骤 3 中的图像 1,1
    • Try to seperate the front cover from the rest of the phone. The front cover is held by four plastic clips.
    • The first time you do this you may have to use some force but do it in a controlled way. If you break the plastic clips you'll need a new front cover.
  4. Disassembling the Nokia 6300: 步骤 4 中的图像 1,1
    • You can take off the keypad now, this is sitting loose on top of the sensors.
    • Unscrew the four remaining T6 Torx screws.
    • The screws holding the motherboard in place are different from the two previous screws which held the rear cover in place.
  5. Disassembling the Nokia 6300: 步骤 5 中的图像 1,1
    • The motherboard with it's screen are now loose, you can pop it right out.
    • If you've been using this phone for a while, there's probably some dust inside the back shell.
    • There's a lot of contacts exposed, so make sure not to damage those.
  6. Disassembling the Nokia 6300: 步骤 6 中的图像 1,3 Disassembling the Nokia 6300: 步骤 6 中的图像 2,3 Disassembling the Nokia 6300: 步骤 6 中的图像 3,3
    • There's your phone!
结论
20等其他人完成本指南。
LucasJV
于05/18/10注册
735 声望
创作了3篇指南
团队
Verheij.co Verheij.co 的会员
Business
1 名成员
创作了5篇指南
一条评论
in this where is bluetooth module plzz give me ans @ bhatia.abhi98@gmail.com
abhishek - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 33
总计 23,680
