跳转到主内容
Disassembling the Nintendo 64 (without special tools)
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Disassembling the Nintendo 64 (without special tools), Disassembling the Nintendo 64 (without special tools): 步骤 1 中的图像 1,1
    • You will need a kitchen lighter and a plastic pen shell, and you will want to do this outdoors to allow the plastic the burn into the air instead of trapping it in a room. Heat the tip of the empty pen shell until it melts into a glob.
  2. Disassembling the Nintendo 64 (without special tools): 步骤 2 中的图像 1,1
    • Stick the pen into one of the 6 holes on the bottom of the Nintendo 64. When it reaches the screw, press forcefully for about three seconds and then let go.
    • TIP: The circled hole has the smallest inner diameter, so if you mold your pen with this hole, you can remove the others without remolding if you are careful not to strip it.
  3. Disassembling the Nintendo 64 (without special tools): 步骤 3 中的图像 1,1
    • Allow the pen to reform and solidify around the screw for 4 to 5 minutes. If done correctly, the pen will mold completely around the specialized screw and grip it so that it can be twisted out.
  4. Disassembling the Nintendo 64 (without special tools): 步骤 4 中的图像 1,1
    • Grip the pen and, pushing down forcefully, begin to twist it loose (to the left) as if you were using an actual screwdriver. The screw should come out with the pen as shown in the picture if done flawlessly. If not, you can still manage to get the screw out without it molding completely.
  5. Disassembling the Nintendo 64 (without special tools): 步骤 5 中的图像 1,1
    • Repeat the melting and re-solidifying process 5 more times for the rest of the screws, and the console will be ready to be opened up for repair.
  6. Disassembling the Nintendo 64 (without special tools): 步骤 6 中的图像 1,1
    • Open the outer shell of the case if it is not already opened. For a how-to on that, go here.
  7. Disassembling the Nintendo 64 (without special tools): 步骤 7 中的图像 1,1
    • Once the case is off, turn your attention to the silver plate covering the green motherboard underneath. Begin unscrewing the screws connecting the plate to the motherboard.
    • Also remove the two smaller screws on the expansion slot.
  8. Disassembling the Nintendo 64 (without special tools): 步骤 8 中的图像 1,1
    • The motherboard is now free to be worked on.
结论
9等其他人完成本指南。
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 18,029
