跳转到主内容
Disassembling the Garmin eTrex Vista-H Outer Case
你所需要的
  1. Disassembling the Garmin eTrex Vista-H Outer Case, Removing Battery: 步骤 1 中的图像 1,1
    • Flip the device to the backside, and locate the metal tab at the center of the back cover.
  2. Disassembling the Garmin eTrex Vista-H Outer Case: 步骤 2 中的图像 1,1
    • Lift the metal tab up, and rotate it counterclockwise. This will unlock the back case cover.
  3. Disassembling the Garmin eTrex Vista-H Outer Case: 步骤 3 中的图像 1,2 Disassembling the Garmin eTrex Vista-H Outer Case: 步骤 3 中的图像 2,2
    • Lift the battery plate off to either insert or remove 2 AA batteries.
  4. Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: 步骤 4 中的图像 1,2 Disassembling the Garmin eTrex Vista-H Outer Case, Disassembling the Garmin eTrex Vista-H Outer Case: 步骤 4 中的图像 2,2
    • With the wedge side of a spudger (or a small, flat head screwdriver), remove the black rubber case support from the device body.
  5. Disassembling the Garmin eTrex Vista-H Outer Case: 步骤 5 中的图像 1,3 Disassembling the Garmin eTrex Vista-H Outer Case: 步骤 5 中的图像 2,3 Disassembling the Garmin eTrex Vista-H Outer Case: 步骤 5 中的图像 3,3
    在这个步骤中使用的工具:
    购买
    • With the pick side of a spudger (or tweezers), peel the sticky tape from the device.
  6. Disassembling the Garmin eTrex Vista-H Outer Case: 步骤 6 中的图像 1,1
    • Split the front and rear panels by inserting a small pointed tool (such as a pen point or a screwdriver tip SL1.5) in the 5 plastic tabs along the sides of the device.
    • Do not remove the back panels quickly. If too much force is applied, there is a wire connection that will break.
    • CAUTION! Be careful not to force the tabs inward. This will result in broken tabs.
  7. Disassembling the Garmin eTrex Vista-H Outer Case: 步骤 7 中的图像 1,2 Disassembling the Garmin eTrex Vista-H Outer Case: 步骤 7 中的图像 2,2
    • With tweezers (or your fingernails), carefully disconnect the wires between the PC input and the motherboard.
结论
7等其他人完成本指南。
Ryan Green
于10/17/10注册
93 声望
撰写一个指南
团队
Cal Poly, Team 21-30, Regan Fall 2010 Cal Poly, Team 21-30, Regan Fall 2010 的会员
CPSU-REGAN-F10S21G30
3 名成员
创作了5篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 4
过去 30 天: 13
总计 5,017
