跳转到主内容
Disassembling the Ematic Genesis
你所需要的
  1. Disassembling the Ematic Genesis, Ematic Genesis Casing: 步骤 1 中的图像 1,3 Disassembling the Ematic Genesis, Ematic Genesis Casing: 步骤 1 中的图像 2,3 Disassembling the Ematic Genesis, Ematic Genesis Casing: 步骤 1 中的图像 3,3
    • Unscrew the two (2) 1.3mm Phillips #00 screws found on the bottom edge of the tablet, where the power and volume buttons are located.
  2. Disassembling the Ematic Genesis: 步骤 2 中的图像 1,3 Disassembling the Ematic Genesis: 步骤 2 中的图像 2,3 Disassembling the Ematic Genesis: 步骤 2 中的图像 3,3
    • Insert plastic opening tool into the edge between the screen plate and the back plate to create a separation between the casings.
    • Insert the flat end of the spudger next to the plastic opening tool and carefully pry the edges apart. Continue this all around the edges until the casings separate.
    • There may be cracking sounds when prying them apart. If carefully done, this is only the locks coming apart and is not harmful.
    • Be careful when separating the two plates as they are connected by the speaker wires and could be disconnected during this process.
  3. Disassembling the Ematic Genesis: 步骤 3 中的图像 1,1
    • Remove back plate from screen plate and lay both down flat next to each other.
结论
Justin Rohrman
于03/23/15注册
745 声望
创作了6篇指南
团队
Baylor, Team 4-3, Williams Spring 2015 Baylor, Team 4-3, Williams Spring 2015 的会员
BU-WILLIAMS-S15S4G3
3 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 414
