本指南有最近更改,您可查看未经巡查的最新版本。
简介
This guide explains how to remove the bumper from your Roomba.
你所需要的
With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
另外一个人完成了本指南。
一条评论
Mine had a wire leading from the body to the bumper. The bumper end was held on by two small Phillips screws, which I undid to disconnect it (the bit it screws on to falls off the top of the bumper).
When putting it back together, make sure to put it on again the right way round, with the wire towards the front of the roomba (i.e. furthest from the main body), otherwise you will find the wire gets in the way of the bumper working, and you'll have to take it all apart again, like I did!
