跳转到主内容
Disassembling iRobot Roomba 551 Bumper
你所需要的
  1. Disassembling iRobot Roomba 551 Bumper, Side Brush: 步骤 1 中的图像 1,1
    • Place your Roomba upside-down on a hard surface.
  2. Disassembling iRobot Roomba 551 Bumper: 步骤 2 中的图像 1,1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. Disassembling iRobot Roomba 551 Bumper: 步骤 3 中的图像 1,1
    • Gently pull upwards on the brush to remove it.
  4. Disassembling iRobot Roomba 551 Bumper, Bottom Plate: 步骤 4 中的图像 1,1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. Disassembling iRobot Roomba 551 Bumper: 步骤 5 中的图像 1,2 Disassembling iRobot Roomba 551 Bumper: 步骤 5 中的图像 2,2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. Disassembling iRobot Roomba 551 Bumper: 步骤 6 中的图像 1,1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
  7. Disassembling iRobot Roomba 551 Bumper, Bumper: 步骤 7 中的图像 1,3 Disassembling iRobot Roomba 551 Bumper, Bumper: 步骤 7 中的图像 2,3 Disassembling iRobot Roomba 551 Bumper, Bumper: 步骤 7 中的图像 3,3
    • With a Phillips #1 screwdriver, remove the ten 12mm screws located along the bottom of the bumper.
  8. Disassembling iRobot Roomba 551 Bumper: 步骤 8 中的图像 1,1
    • Lift the bottom cover and set it to the side.
  9. Disassembling iRobot Roomba 551 Bumper: 步骤 9 中的图像 1,2 Disassembling iRobot Roomba 551 Bumper: 步骤 9 中的图像 2,2
    • Flip the Roomba over, grasp the bumper, and gently lift to remove.
    • The battery is not secured in place once the bottom plate has been removed, and may fall out when the Roomba is turned right-side up.
结论
另外一个人完成了本指南。
Cody Rhoads
于01/16/14注册
348 声望
创作了2篇指南
团队
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G14
4 名成员
创作了19篇指南
一条评论
Mine had a wire leading from the body to the bumper. The bumper end was held on by two small Phillips screws, which I undid to disconnect it (the bit it screws on to falls off the top of the bumper).
When putting it back together, make sure to put it on again the right way round, with the wire towards the front of the roomba (i.e. furthest from the main body), otherwise you will find the wire gets in the way of the bumper working, and you'll have to take it all apart again, like I did!
Nikki Locke - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 3
总计 2,596
