跳转到主内容
Disassembling iRobot Roomba 551 Bottom Plate
你所需要的
  1. Disassembling iRobot Roomba 551 Bottom Plate, Side Brush: 步骤 1 中的图像 1,1
    • Place your Roomba upside-down on a hard surface.
  2. Disassembling iRobot Roomba 551 Bottom Plate: 步骤 2 中的图像 1,1
    • While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
  3. Disassembling iRobot Roomba 551 Bottom Plate: 步骤 3 中的图像 1,1
    • Gently pull upwards on the brush to remove it.
  4. Disassembling iRobot Roomba 551 Bottom Plate, Bottom Plate: 步骤 4 中的图像 1,1
    • Rotate the Roomba upside-down so the bottom is facing towards you.
  5. Disassembling iRobot Roomba 551 Bottom Plate: 步骤 5 中的图像 1,2 Disassembling iRobot Roomba 551 Bottom Plate: 步骤 5 中的图像 2,2
    • Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
  6. Disassembling iRobot Roomba 551 Bottom Plate: 步骤 6 中的图像 1,1
    • Carefully lift the bottom plate.
    • The battery is only secured in place by the bottom plate, and may fall out once the bottom plate is removed.
结论
团队
Cal Poly, Team 13-14, Regan Winter 2014 Cal Poly, Team 13-14, Regan Winter 2014 的会员
CPSU-REGAN-W14S13G14
4 名成员
创作了19篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 52
总计 2,278
