跳转到主内容
Disassembling iPhone 4S Vibrator
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Disassembling iPhone 4S Vibrator, Disassembling iPhone 4S Battery: 步骤 1 中的图像 1,1
    • Using a 5-point pentalobe screwdriver, unscrew the 2 pentalobe on the bottom of the phone near the dock connector.
  2. Disassembling iPhone 4S Vibrator: 步骤 2 中的图像 1,1
    • Push the back glass towards the top of the phone.
  3. Disassembling iPhone 4S Vibrator: 步骤 3 中的图像 1,1
    • Using a #000 Phillips screwdriver, unscrew the 2 very small Phillips screws.
  4. Disassembling iPhone 4S Vibrator: 步骤 4 中的图像 1,2 Disassembling iPhone 4S Vibrator: 步骤 4 中的图像 2,2
    • Using a plastic opener tool, pry up the battery connector shield. Be careful not to lose the smaller antenna connector shield under the top connector sheild.
    • Using a plastic opener tool, pry up the battery connector.
  5. Disassembling iPhone 4S Vibrator: 步骤 5 中的图像 1,1
    • Pull upwards on the plastic tab. If it's the first time, you may have to use the plastic pry tool on the outside (right) edge of the battery to loosen battery first.
    • Then, out pops the battery.
  6. Disassembling iPhone 4S Vibrator, Disassembling iPhone 4S Logic Board: 步骤 6 中的图像 1,1
    • Disconnect the antenna cable from the logic board.
  7. Disassembling iPhone 4S Vibrator: 步骤 7 中的图像 1,1
    • Unscrew the 2 phillips screws holding the shield covering the dock connector ribbon.
    • One of the screws is .2 millimeters longer than the other.
  8. Disassembling iPhone 4S Vibrator: 步骤 8 中的图像 1,2 Disassembling iPhone 4S Vibrator: 步骤 8 中的图像 2,2
    • Disconnect the dock connector ribbon from the logic board.
    • Pull the cable up and flow it to the side.
  9. Disassembling iPhone 4S Vibrator: 步骤 9 中的图像 1,2 Disassembling iPhone 4S Vibrator: 步骤 9 中的图像 2,2
    • Unscrew the 4 screws holding the large shield and the single screw holding the small shield.
  10. Disassembling iPhone 4S Vibrator: 步骤 10 中的图像 1,1
    • Using the plastic opening tool, pry up the 7 connectors on the top of the logic board.
    • The back camera will come out, make sure you get the small piece of black plastic covering the back of the camera.
  11. Disassembling iPhone 4S Vibrator: 步骤 11 中的图像 1,2 Disassembling iPhone 4S Vibrator: 步骤 11 中的图像 2,2
    • Unscrew the 2 flat head screws.
    • Unscrew the 3 phillips head screws, the top one is covered by a small piece of black tape.
  12. Disassembling iPhone 4S Vibrator: 步骤 12 中的图像 1,1
    • Using your fingers or a plastic opening tool carefully pull out the logic board.
  13. Disassembling iPhone 4S Vibrator, Disassembling iPhone 4S Vibrator: 步骤 13 中的图像 1,2 Disassembling iPhone 4S Vibrator, Disassembling iPhone 4S Vibrator: 步骤 13 中的图像 2,2
    • Pry the vibrator up off the metal.
结论
2等其他人完成本指南。
Chandler Skinner
于10/15/11注册
3,710 声望
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 2,471
