跳转到主内容
Disassembling ZTE Racer II Phone
你所需要的
  1. Disassembling ZTE Racer II Phone, Phone: 步骤 1 中的图像 1,1
    • Carefully prise the back cover off the phone.
  2. Disassembling ZTE Racer II Phone: 步骤 2 中的图像 1,1
    • Remove Battery, SIM Card, and MicroSD
    • Remove the four screws located around the edge of the case. They should be very small phillips heads.
  3. Disassembling ZTE Racer II Phone: 步骤 3 中的图像 1,1
    • Using a flathead screwdriver, carefully prise the black plastic away. It's held in with a series of clips, and should come away easily.
  4. Disassembling ZTE Racer II Phone: 步骤 4 中的图像 1,1
    • Carefully remove the ribbon cable that connects the capacitive screen to the main board. You need to carefully lift the small tab, then pull the cable out.
  5. Disassembling ZTE Racer II Phone: 步骤 5 中的图像 1,2 Disassembling ZTE Racer II Phone: 步骤 5 中的图像 2,2
    • Now using the flathead screwdriver, prise the plastic that makes up the front, away from the circuit board. Like the back piece, it has a series of clips around the edge, and should lift free without much effort.
  6. Disassembling ZTE Racer II Phone: 步骤 6 中的图像 1,2 Disassembling ZTE Racer II Phone: 步骤 6 中的图像 2,2
    • There you have it. Amazingly simple to take apart this phone.
结论
另外一个人完成了本指南。
Jacob
于04/27/13注册
121 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 1,914
