简介
I get error messages that filer is full or wet so i need to clean it or replace. It was too often even with new replaced filter in dust bin. When it was new it was not the issue so i thought that there must be some non replaceable filters inside and sure there are some inside also. The disassemble is little more that expected to get to them but its not very hard
All tools you will need is ph1/ph2 driver and flat spudger
Remove Brush and its cover
Remove dust container (opposite side)
To remove bottom cover just remove all visible ph2 screws (one of them is covered with white warranty sticker)
All are the same size and length - you can put them aside. Inner screws are different ones
Top cover is clip on only. Check the image for locations. This is probably only risky part of disasembly
Left and Right edge ones have little larger holes - that helps when you try to put it back
I was not able to fully open bottom cover even after removing all screws until i removed LiDAR also. Its hard to believe but to open bottom you must remove it from top
3 unique screws are hidden under white rubber
2 smaller screws are holding hinge and are same screws as rest LiDar uses - dont chage with screws from bottom - they are same diameter but shorter
4 Screws are inside cover
Side Brush
Main Brush with motor assembly
Both wheels has 3 screws, you will need little longer screwdriver
After remove wheel, you can rotate the hole to see screws
3等其他人完成本指南。
