跳转到主内容
Disassembling Xbox 360 E Top Panel
你所需要的
  1. Disassembling Xbox 360 E Top Panel, Top Panel: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Spudger
    $2.99
    购买
    • Push the Spudger into the crevice between the grated top panel of the Xbox and the bottom body with the rubber feet.
    • Pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  2. Disassembling Xbox 360 E Top Panel: 步骤 2 中的图像 1,1
    • Slide the spudger along the separation you have created between the grated panel and the bottom body of the Xbox.
    • Periodically pull back on the spudger like a lever, keeping it pressed firmly into the crevice.
  3. Disassembling Xbox 360 E Top Panel: 步骤 3 中的图像 1,3 Disassembling Xbox 360 E Top Panel: 步骤 3 中的图像 2,3 Disassembling Xbox 360 E Top Panel: 步骤 3 中的图像 3,3
    • Continue sliding the spudger along the perimeter of the left grated face of the Xbox.
    • Pull the top panel off.
结论
4等其他人完成本指南。
Jennifer
于02/02/14注册
1,909 声望
创作了4篇指南
团队
Cal Poly, Team 2-11, Amido Winter 2014 Cal Poly, Team 2-11, Amido Winter 2014 的会员
CPSU-AMIDO-W14S2G11
4 名成员
创作了43篇指南
一条评论
I broke my spudger! May I use anything besides that?
Colin2 Schrek - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 8
过去 30 天: 32
总计 2,488
