跳转到主内容
Disassembling Wii Balance Board
你所需要的
  1. Disassembling Wii Balance Board, Floor Unit: 步骤 1 中的图像 1,1
    • Unscrew these #1 Philips screws, and leave them in the plastic foot holders.
  2. Disassembling Wii Balance Board: 步骤 2 中的图像 1,1
    • Remove the foot holders and place them on the side
  3. Disassembling Wii Balance Board: 步骤 3 中的图像 1,1
    • Remove the four feet and place them on the side
  4. Disassembling Wii Balance Board: 步骤 4 中的图像 1,1
    • Remove these #1 Philips screws, and leave them in their counterbores
  5. Disassembling Wii Balance Board: 步骤 5 中的图像 1,1
    • Lift grey shell off and place to the side to reveal:
    • ADC and Logic board
    • Bluetooth module
    • Strain gauges
    • Battery holder
  6. Disassembling Wii Balance Board: 步骤 6 中的图像 1,1
    • The ADC and Logic board contains:
    • Bluetooth module
    • Power button connector
    • Battery and sync button connector
    • Strain gauge wheatstone bridge connections
    • The topmost connection for each of the four bridge connections is the ground; relative to this, the two middle connections should be at 1.2 VDC, and the bottom should be at 2.7 VDC
结论
15等其他人完成本指南。
Pete Marchetto
于01/25/11注册
667 声望
创作了2篇指南
5条评论
Great stuff Pete, being able to fix the wifi board got me mucho street cred with " her indoors " and lots of other goodies that go along with that
HENRY - 回复
Can I take out the battery box without removing the bottom?
Richard Merchant - 回复
No, you can't. You will have to follow this procedure completely.
paulo lima -
Thank you! I was able to fix our 10 year old balance board.
the kids think I’m a roakstar, for now anyway.
lisadubya - 回复
is there schematics for the power pcb
Josué Hernandez - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 34
总计 12,197
