配件
无需配件。
  1. Use a large plastic opening tool along the rear panel: There are 4 clips to release. There are 4 clips to release.
    • Use a large plastic opening tool along the rear panel:
    • There are 4 clips to release.
  2. Slide the cover along the plastic frame. Slide the cover along the plastic frame.
    • Slide the cover along the plastic frame.
  3. Slide off the largest plastic pieces.
    • Slide off the largest plastic pieces.
  4. 所有超过US$100或包含 Pro Tech工具包的订单免费送货!
    浏览我们的商店
  5. Bend the second small plastic piece to release it from the rubber piece. Now you can slide it out. Now you can slide it out.
    • Bend the second small plastic piece to release it from the rubber piece.
    • Now you can slide it out.
  6. Slide out the hard drive as shown in the picture Make sure to slide as shown or you may damage the USB bridge logic board.
    • Slide out the hard drive as shown in the picture
    • Make sure to slide as shown or you may damage the USB bridge logic board.
  7. Remove the 4 rubber piece from the plastic frame at each corner. Remove the 4 rubber piece from the plastic frame at each corner.
    • Remove the 4 rubber piece from the plastic frame at each corner.
  8. Remove the rubber piece from the  SATA/USB bridge logic board.
    • Remove the rubber piece from the SATA/USB bridge logic board.
  9. Remove both screws holding the retaining plate and the hard drive. Slide the retaining plate in order to disconnect the SATA connector.
    • Remove both screws holding the retaining plate and the hard drive.
    • Slide the retaining plate in order to disconnect the SATA connector.
  10. Remove both screws holding the retaining plate with the logic board.
    • Remove both screws holding the retaining plate with the logic board.
结论
Gaetan
于2012年12月26日注册
9,349 信誉积分
创作了18篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 2
过去的30天: 19
总计 1,418
