跳转到主内容
Disassembling Western Digital Essentials HD Anti-vibration rubber pieces
你所需要的
  1. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Case: 步骤 1 中的图像 1,3 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Case: 步骤 1 中的图像 2,3 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Case: 步骤 1 中的图像 3,3
    • Use a large plastic opening tool along the rear panel:
    • There are 4 clips to release.
  2. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: 步骤 2 中的图像 1,2 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: 步骤 2 中的图像 2,2
    • Slide the cover along the plastic frame.
  3. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, LED Light conducting plastic pieces: 步骤 3 中的图像 1,1
    • Slide off the largest plastic pieces.
  4. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: 步骤 4 中的图像 1,3 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: 步骤 4 中的图像 2,3 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: 步骤 4 中的图像 3,3
    • Bend the second small plastic piece to release it from the rubber piece.
    • Now you can slide it out.
  5. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Disassembling Western Digital Essentials HD Hard Drive: 步骤 5 中的图像 1,2 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Disassembling Western Digital Essentials HD Hard Drive: 步骤 5 中的图像 2,2
    • Slide out the hard drive as shown in the picture
    • Make sure to slide as shown or you may damage the USB bridge logic board.
  6. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: 步骤 6 中的图像 1,2 Disassembling Western Digital Essentials HD Anti-vibration rubber pieces, Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: 步骤 6 中的图像 2,2
    • Remove the 4 rubber piece from the plastic frame at each corner.
  7. Disassembling Western Digital Essentials HD Anti-vibration rubber pieces: 步骤 7 中的图像 1,1
    • Remove the rubber piece from the SATA/USB bridge logic board.
结论
Gaetan
于12/26/12注册
9,574 声望
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 1,555
