跳转到主内容
Disassembling Western Digital Elements SE HD case and mainboard
你所需要的
  1. Disassembling Western Digital Elements SE HD case and mainboard, Opening the case: 步骤 1 中的图像 1,1
    在这个步骤中使用的工具:
    Plastic Cards
    $2.99
    • The case can be opened easily with a plastic case opening tool. Strong finger nails and an old credit card / plastic card may work too.
  2. Disassembling Western Digital Elements SE HD case and mainboard, Remove marked screws (T5): 步骤 2 中的图像 1,1
    • The 5 marked screws can be removed with a Torx T5.
  3. Disassembling Western Digital Elements SE HD case and mainboard, Lift up the board: 步骤 3 中的图像 1,2 Disassembling Western Digital Elements SE HD case and mainboard, Lift up the board: 步骤 3 中的图像 2,2
    • Lift the board gently - there is only one small connector connecting the board to the hard disk case (around the yellow market space).
    • On the second image, you can see the board turned over.
    • Further disassembly would damage the disk. I hoped to find a SATA connector within, but maybe someone knows an alternative board with the same connector.
  4. Disassembling Western Digital Elements SE HD case and mainboard, Hard disk labels and case labels: 步骤 4 中的图像 1,2 Disassembling Western Digital Elements SE HD case and mainboard, Hard disk labels and case labels: 步骤 4 中的图像 2,2
    • The label on the WD Elements SE case and the labels on the harddisk can be seen here. I censored serial numbers, the WWID and the barcodes.
结论
另外一个人完成了本指南。
Bastli
于12/30/23注册
283 声望
创作了2篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 4
过去 7 天: 25
过去 30 天: 110
总计 1,653
