跳转到主内容
Disassembling VTech MobiGo Touch Learning System Screen Enclosure
你所需要的
  1. Disassembling VTech MobiGo Touch Learning System Screen Enclosure, Case: 步骤 1 中的图像 1,1
    • Remove the battery covers and the four batteries.
  2. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: 步骤 2 中的图像 1,2 Disassembling VTech MobiGo Touch Learning System Screen Enclosure: 步骤 2 中的图像 2,2
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: 步骤 3 中的图像 1,2 Disassembling VTech MobiGo Touch Learning System Screen Enclosure: 步骤 3 中的图像 2,2
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. Disassembling VTech MobiGo Touch Learning System Screen Enclosure, Disassembling VTech MobiGo Touch Learning System Screen Enclosure: 步骤 4 中的图像 1,1
    • Remove the three 4.0 mm Philips J0 screws holding the "L" shaped brackets in place.
  5. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: 步骤 5 中的图像 1,1
    • Remove the three "L" shaped brackets and the spring.
  6. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: 步骤 6 中的图像 1,1
    • Flip the device over and remove the three 4.0 mm Philips J0 case screws.
  7. Disassembling VTech MobiGo Touch Learning System Screen Enclosure: 步骤 7 中的图像 1,1
    • Separate the front and back of the case.
    • Use a plastic opening tool if necessary.
结论
2等其他人完成本指南。
Daniel Kresge
于09/01/15注册
385 声望
创作了4篇指南
团队
USF Tampa, Team 8-3, Eyestone Fall 2015 USF Tampa, Team 8-3, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G3
3 名成员
创作了17篇指南
1指南评论
Does anyone know what company in china sells the touch screen replacement?
Anthony Shaw - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 33
总计 2,420
