跳转到主内容
Disassembling VTech MobiGo Touch Learning System Keyboard
你所需要的
  1. Disassembling VTech MobiGo Touch Learning System Keyboard, Case: 步骤 1 中的图像 1,1
    • Remove the battery covers and the four batteries.
  2. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 2 中的图像 1,2 Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 2 中的图像 2,2
    • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
    • Remove the eight 6.0 mm JIS #0 case screws.
  3. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 3 中的图像 1,2 Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 3 中的图像 2,2
    • Using a plastic opening tool, separate the two pieces of the case carefully.
  4. Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 4 中的图像 1,2 Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 4 中的图像 2,2
    • Remove the six 6.5 mm Philips J0 screws that are connected to the circuit board.
    • Use light pressure to prevent damage to the circuit board.
  5. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 5 中的图像 1,1
    • Remove the 9.0 mm Philips J0 screw from the blue plastic cover.
    • Once the screw is removed, remove the blue plastic cover.
  6. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 6 中的图像 1,2 Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 6 中的图像 2,2
    • Remove the two 4.0 mm Philips J0 screws located on the orange case.
    • Use gentle force to prevent stripping of screws.
  7. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 7 中的图像 1,3 Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 7 中的图像 2,3 Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 7 中的图像 3,3
    • Remove the two "L" shaped brackets located on both sides of the device.
    • Use the magnetic mat to store these brackets.
  8. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 8 中的图像 1,1
    • Locate the spring that was connected to the "L" shaped bracket and slowly remove it.
  9. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 9 中的图像 1,2 Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 9 中的图像 2,2
    • Gently lift the circuit board from the case using a plastic opening tool.
    • Make sure to use a plastic opening tool for this step.
  10. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 10 中的图像 1,1
    • Remove the 3.5 mm Philips J0 screw located underneath the circuit board.
    • Keep the circuit board out of the way to avoid damaging it.
  11. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 11 中的图像 1,1
    • Slowly remove the keyboard panel.
    • Use a spudger if necessary.
    • The keys will fall out once the keyboard panel is removed.
    • Remove all of the keys and set them aside with the keyboard panel.
  12. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 12 中的图像 1,1
    • Gently remove the keyboard circuit board with a plastic opening tool.
    Where do you get a replacement circuit board?
    Kara - 回复
结论
RBansil
于08/27/15注册
221 声望
创作了2篇指南
团队
USF Tampa, Team 8-3, Eyestone Fall 2015 USF Tampa, Team 8-3, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G3
3 名成员
创作了17篇指南
一条评论
Was gifted a mobigo2 for my niece but it came without keyboard .. I was curious if you knew where I might find a replacement keyboard?
ROXXY - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 13
总计 1,754
