跳转到主内容
加入维修社区 - 创建账户
Disassembling VTech MobiGo Touch Learning System Keyboard
你所需要的
    1. Disassembling VTech MobiGo Touch Learning System Keyboard, Case: 步骤 1 中的图像 1,1
      • Remove the battery covers and the four batteries.
      询问修复机器人
      添加评论
    2. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 2 中的图像 1,2 Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 2 中的图像 2,2
      • Remove the four plastic caps with a metal spudger to expose the 6.0 mm Philips JIS #0 case screws.
      • Remove the eight 6.0 mm JIS #0 case screws.
      询问修复机器人
      添加评论
    3. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 3 中的图像 1,2 Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 3 中的图像 2,2
      • Using a plastic opening tool, separate the two pieces of the case carefully.
      询问修复机器人
      添加评论
    1. Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 4 中的图像 1,2 Disassembling VTech MobiGo Touch Learning System Keyboard, Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 4 中的图像 2,2
      • Remove the six 6.5 mm Philips J0 screws that are connected to the circuit board.
      • Use light pressure to prevent damage to the circuit board.
      询问修复机器人
      添加评论
    2. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 5 中的图像 1,1
      • Remove the 9.0 mm Philips J0 screw from the blue plastic cover.
      • Once the screw is removed, remove the blue plastic cover.
      询问修复机器人
      添加评论
    3. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 6 中的图像 1,2 Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 6 中的图像 2,2
      • Remove the two 4.0 mm Philips J0 screws located on the orange case.
      • Use gentle force to prevent stripping of screws.
      询问修复机器人
      添加评论
    4. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 7 中的图像 1,3 Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 7 中的图像 2,3 Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 7 中的图像 3,3
      • Remove the two "L" shaped brackets located on both sides of the device.
      • Use the magnetic mat to store these brackets.
      询问修复机器人
      添加评论
    5. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 8 中的图像 1,1
      • Locate the spring that was connected to the "L" shaped bracket and slowly remove it.
      询问修复机器人
      添加评论
    6. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 9 中的图像 1,2 Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 9 中的图像 2,2
      • Gently lift the circuit board from the case using a plastic opening tool.
      • Make sure to use a plastic opening tool for this step.
      询问修复机器人
      添加评论
    7. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 10 中的图像 1,1
      • Remove the 3.5 mm Philips J0 screw located underneath the circuit board.
      • Keep the circuit board out of the way to avoid damaging it.
      询问修复机器人
      添加评论
    8. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 11 中的图像 1,1
      • Slowly remove the keyboard panel.
      • Use a spudger if necessary.
      • The keys will fall out once the keyboard panel is removed.
      • Remove all of the keys and set them aside with the keyboard panel.
      询问修复机器人
      添加评论
    9. Disassembling VTech MobiGo Touch Learning System Keyboard: 步骤 12 中的图像 1,1
      • Gently remove the keyboard circuit board with a plastic opening tool.
      添加评论
结论
取消:我没有完成这个指南。
RBansil
于08/27/15注册
221 声望
创作了2篇指南
团队
USF Tampa, Team 8-3, Eyestone Fall 2015 USF Tampa, Team 8-3, Eyestone Fall 2015 的会员
USFT-EYESTONE-F15S8G3
3 名成员
创作了49篇指南
1指南评论
Was gifted a mobigo2 for my niece but it came without keyboard .. I was curious if you knew where I might find a replacement keyboard?
ROXXY - 回复 分享
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 34
总计 2,468
