跳转到主内容
Disassembling Uniden R8 Radar Detector
你所需要的
    • Turn the detector off and unplug all cables, mounts, and accessories.
    • Place the unit face-down on an ESD-safe surface.
    • Clean hands or wear gloves to avoid contaminating the interior.
  1. Disassembling Uniden R8 Radar Detector, Remove the four bottom screws: 步骤 2 中的图像 1,1
    • Locate the four Phillips screws on the bottom shell.
    • Using a Phillips #0, remove all four screws.
    • Sort and label the screws so you can return them to their original locations.
  2. Disassembling Uniden R8 Radar Detector, Lift the top cover (watch the USB-Micro port): 步骤 3 中的图像 1,1
    • Starting at a rear corner, gently lift the top cover.
    • As the cover rises, watch the USB-Micro opening: the plastic lip can catch on the port.
    • If it binds, insert a plastic pick between the shell and the port cutout to relieve pressure.
    • Optional—access to speaker and adjacent parts:
    • Carefully lift the main board just enough to reach the speaker (and nearby connectors/components).
    • Handle the board by the edges only. Do not yank, watch for any wires or short ribbon leads attached underneath.
    • If a connector resists, use a spudger to gently work it free; avoid prying on components.
结论
Cooper Varney
于04/28/25注册
97 声望
撰写一个指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 6
过去 30 天: 20
总计 59
