跳转到主内容
Disassembling Trek 820 Tire Removal from Wheel
你所需要的
  1. Disassembling Trek 820 Tire Removal from Wheel, Tire: 步骤 1 中的图像 1,1
    • Locate the valve stem and remove the valve stem cap if one is present.
  2. Disassembling Trek 820 Tire Removal from Wheel: 步骤 2 中的图像 1,1
    • Begin releasing tire air pressure by pressing down on the small rod in the center of the valve stem. A hissing sound will indicated that air is leaving the tire.
    • Continue to release air until the tire becomes soft and flexible. The hissing sound should become quiet or stop altogether.
  3. Disassembling Trek 820 Tire Removal from Wheel: 步骤 3 中的图像 1,2 Disassembling Trek 820 Tire Removal from Wheel: 步骤 3 中的图像 2,2
    • Insert the flathead screwdriver, or another sturdy, long object, between the edge of the tire and the wheel rim.
    • Be careful not to damage the inner tube when inserting and moving the screwdriver or other tool. The inner tube is fragile and may be pinched between the wheel rim and tool.
    • Work the edge of the tire out of the wheel rim using a screwdriver, pulling the edge of the tire away from the center of the wheel and out of the rim.
  4. Disassembling Trek 820 Tire Removal from Wheel: 步骤 4 中的图像 1,3 Disassembling Trek 820 Tire Removal from Wheel: 步骤 4 中的图像 2,3 Disassembling Trek 820 Tire Removal from Wheel: 步骤 4 中的图像 3,3
    • Continue around the wheel rim until the whole tire is free from the rim. Now you may separate the tire from the wheel.
    • Be careful not to damage the valve stem as you pull the tire and inner tube off of the wheel rim together.
  5. Disassembling Trek 820 Tire Removal from Wheel: 步骤 5 中的图像 1,2 Disassembling Trek 820 Tire Removal from Wheel: 步骤 5 中的图像 2,2
    • Remove the inner tube from the tire by simply pulling it from the tire carcass.
结论
For tire reinstallation, simply follow these steps in reverse order.
团队
Cal Poly, Team 1-1, Propen Fall 2012 Cal Poly, Team 1-1, Propen Fall 2012 的会员
CPSU-PROPEN-F12S1G1
5 名成员
创作了9篇指南
一条评论
Be very careful using a screwdriver to unseat the tire as it is very likely you will pinch and thus ruin the tube. Better to buy several tire levers at any bike shop - they are inexpensive and made for this job.
John Sinclair - 回复
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 7
总计 1,120
