当前版本的文档还未经巡查,您可以查看最新的已查核版本。
这个步骤还没有翻译 帮忙翻译一下
Flip the laptop over so the bottom is facing up.
Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
Gently lift the battery out of the computer.
Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
Remove the WIFI module cover. It will pull right off.
Unplug the white and black wires from the WiFi module.
Remove the twelve 8mm button head Phillips #00 B8 screws.
Remove the two 14 mm button head Phillips #00 B14 screws.
Remove the two 10 mm Phillips #00 battery compartment screws.
Remove the two 8 mm Phillips #00 screws.
Remove the seven 4mm flat Phillips #00 screws.
Remove the seven 20mm button head Phillips #00 screws.
Use the plastic opening tool to pry the two halves apart.
取消:我没有完成这个指南。
与9其他贡献者
于09/30/13注册
89,953 声望
创作了89篇指南
徽章: 44
+ 41更多徽章
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 232
