跳转到主内容
Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies
仅作为前提条件
本指南仅用作其他指南的先决条件。不能单独食用。
你所需要的
  1. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies, Battery: 步骤 1 中的图像 1,1
    • Flip the laptop over so the bottom is facing up.
    • Slide each of the three tabs on the bottom half of the assembly into the unlocked position.
  2. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: 步骤 2 中的图像 1,1
    • Gently lift the battery out of the computer.
  3. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies, Upper Assembly: 步骤 3 中的图像 1,1
    • Remove the single 3mm Phillips #00 screw that secures the wireless card cover.
  4. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: 步骤 4 中的图像 1,1
    • Remove the WIFI module cover. It will pull right off.
  5. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: 步骤 5 中的图像 1,2 Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: 步骤 5 中的图像 2,2
    • Unplug the white and black wires from the WiFi module.
  6. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: 步骤 6 中的图像 1,1
    • Remove the twelve 8mm button head Phillips #00 B8 screws.
    • Remove the two 14 mm button head Phillips #00 B14 screws.
    • Remove the two 10 mm Phillips #00 battery compartment screws.
    • Remove the two 8 mm Phillips #00 screws.
  7. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: 步骤 7 中的图像 1,1
    • Remove the seven 4mm flat Phillips #00 screws.
    • Remove the seven 20mm button head Phillips #00 screws.
  8. Disassembling Toshiba Satellite A65-S126 Upper and Lower Assemblies: 步骤 8 中的图像 1,1
    • Use the plastic opening tool to pry the two halves apart.
结论
Geoff Wacker
于09/30/13注册
89,898 声望
创作了89篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 232
