跳转到主内容
Disassembling Toshiba NB205 N330PK Back Panels
你所需要的
  1. Disassembling Toshiba NB205 N330PK Back Panels, Disassembling Toshiba NB205 N330PK Back Panels: 步骤 1 中的图像 1,2 Disassembling Toshiba NB205 N330PK Back Panels, Disassembling Toshiba NB205 N330PK Back Panels: 步骤 1 中的图像 2,2
    • Using the Phillips #0 in the bit driver, carefully loosen and remove the single 5mm screw.
    • With the retaining screw removed, lift the panel upwards to separate it from the netbook.
  2. Disassembling Toshiba NB205 N330PK Back Panels: 步骤 2 中的图像 1,2 Disassembling Toshiba NB205 N330PK Back Panels: 步骤 2 中的图像 2,2
    • To replace the panel, do step 1 in reverse:
    • Align the panel slots in the appropriate grooves and set in place.
    • With the bit driver, replace the screw to secure the RAM panel.
  3. Disassembling Toshiba NB205 N330PK Back Panels: 步骤 3 中的图像 1,2 Disassembling Toshiba NB205 N330PK Back Panels: 步骤 3 中的图像 2,2
    • Using the bit driver and the Phillips bit, remove both of the panel's retaining screws.
    • With the screws removed, lift the panel in the designated direction, as depicted in photo, for removal.
    • The hard drive is located beneath this cover and is now accessible.
  4. Disassembling Toshiba NB205 N330PK Back Panels: 步骤 4 中的图像 1,2 Disassembling Toshiba NB205 N330PK Back Panels: 步骤 4 中的图像 2,2
    • To replace the hard drive panel, do step 3 in reverse:
    • Place the panel back in its original position and press down.
    • If the hard drive was removed or replaced during this process, improper installation may prevent the hard drive panel from sitting in the slots properly.
    • With the bit driver and Phillips bit, replace the two retaining screws to secure the cover plate in place.
结论
Mason McCaskill
于10/18/13注册
1,021 声望
创作了9篇指南
团队
Clemson, Team 14-2, Benson Fall 2013 Clemson, Team 14-2, Benson Fall 2013 的会员
CLEM-BENSON-F13S14G2
3 名成员
创作了27篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 21
总计 1,005
