当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
If needed, use the flathead screwdriver to gently pry the panel from the phone.
Using your fingers, lift the panel from the device.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
