跳转到主内容
修复你的物品
维修的权力
商店
简介
Removing the back panel from the Toshiba AT1304T
If you can't get a hold of a Torx 6 Security Screwdriver, a small flathead can be used as a substitute
  1. Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
    • Using a thumb-tack, push-pin, or similar pin, remove the four plastic stoppers located on the back panel.
  2. With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • With the T8 Torx Security Bit Screwdriver, remove the four screws in the designated locations.
    • The T8 Torx Security Bit Screwdriver can be substituted with a small flathead screwdriver. Screw removal may be slightly more difficult however.
  3. If needed, use the flathead screwdriver to gently pry the panel from the phone. Using your fingers, lift the panel from the device.
    • If needed, use the flathead screwdriver to gently pry the panel from the phone.
    • Using your fingers, lift the panel from the device.
结论
另外一个人完成了本指南。
Christopher
于2010年04月22日注册
90 信誉积分
创作了8篇指南
团队
Cal Poly, Team 16-6, Maness Spring 2010 Cal Poly, Team 16-6, Maness Spring 2010 的会员
CPSU-MANESS-S10S16G6
4 名成员
创作了16篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 1
过去的30天: 4
总计 1,936
