跳转到主内容
Disassembling Speak And Spell Case
你所需要的
  1. Disassembling Speak And Spell Case, Case: 步骤 1 中的图像 1,2 Disassembling Speak And Spell Case, Case: 步骤 1 中的图像 2,2
    • Flip the toy over, so that the keypad is facing away from you.
    • Remove two Phillips-head screws.
    • Insert a plastic spudger (or 4!) into the marked holes, and push down and towards the edge to release each catch.
    • It's possible to release each catch one-at-a-time, but easier if you have 4 tools and do them simultaneously.
    • This requires quite a bit of force; be careful.
  2. Disassembling Speak And Spell Case: 步骤 2 中的图像 1,1
    • Separate the two halves of the case to expose the inner PCB, speaker and battery holder.
结论
bushing
于04/23/10注册
10,250 声望
创作了13篇指南
一条评论
I got one of these. I've opened the case and the battery connections are silver and show no corrosion at all. I replaced the batteries, swapped out one of the Word Modules. I got a bit of static once, but now nothing. All the wire connection soldering looks fine. Any ideas?
stevehelium@gmail.com
Stephen Henderson - 回复
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 4,960
