跳转到主内容
Disassembling Sony Xperia J External Features
仅作为前提条件
本指南仅提供前提条件!本指南是另一个程序的一部分,不能单独使用。
你所需要的
  1. Disassembling Sony Xperia J External Features, External Features: 步骤 1 中的图像 1,1
    • You will need a Torx T5 screwdriver, plastic opening tool, and a pincet for this operation.
  2. Disassembling Sony Xperia J External Features: 步骤 2 中的图像 1,1
    • Find the little bracket on the bottom left of the phone (when looking at it upside down) and use the opening tool to pry off the back cover.
  3. Disassembling Sony Xperia J External Features: 步骤 3 中的图像 1,1
    在这个步骤中使用的工具:
    • Remove the silicone cover by squeezing it with the tweezers, there is not much pressure needed.
  4. Disassembling Sony Xperia J External Features: 步骤 4 中的图像 1,3 Disassembling Sony Xperia J External Features: 步骤 4 中的图像 2,3 Disassembling Sony Xperia J External Features: 步骤 4 中的图像 3,3
    • Using the Torx T5 screwdriver remove the four 4.74mm screws.
    • Then remove the two 3.13mm screws
    • Lastly remove 5.90mm screw.
  5. Disassembling Sony Xperia J External Features: 步骤 5 中的图像 1,3 Disassembling Sony Xperia J External Features: 步骤 5 中的图像 2,3 Disassembling Sony Xperia J External Features: 步骤 5 中的图像 3,3
    • Using the tweezers remove the black plate at the bottom of the phone. First insert the tweezers tip at the intersection between the black plate and phone, then just pull the plate up.
    • Repeat the same steps to remove the black plates located at the top left, and top right of the phone.
  6. Disassembling Sony Xperia J External Features: 步骤 6 中的图像 1,1
    • After removing the top left black plate, you will find another 3.13mm screw. Just remove it by using the screwdriver.
  7. Disassembling Sony Xperia J External Features: 步骤 7 中的图像 1,1
    • Place the plastic opening tool in-between the black external case of the phone and the silver case, then move it along the edges of the phone to detach the plates.
结论
另外一个人完成了本指南。
Andres Pico
于01/21/15注册
276 声望
撰写一个指南
团队
USF Tampa, Team 4-3, Brown Winter 2015 USF Tampa, Team 4-3, Brown Winter 2015 的会员
USFT-BROWN-W15S4G3
3 名成员
创作了6篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 2
总计 72
