跳转到主内容
Disassembling Sony Vaio VGN-FW 590 Audio USB Board
你所需要的
  1. Disassembling Sony Vaio VGN-FW 590 Audio USB Board, Audio USB Board: 步骤 1 中的图像 1,1
    • - Remove battery.
    • - Remove memory tray door (1 Screw).
    • - Remove hard drive door (1 Screw).
    • - Remove hard drive (3 Screws).
  2. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: 步骤 2 中的图像 1,1
    • - Remove all screws from the bottom cover. There are three types of screws. Marked here with Red Circles, Red Squares and Orange Circles.
  3. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: 步骤 3 中的图像 1,1
    • - Remove CD/DVD Drive by sliding it out.
    • - Remove three more screws, which were hiding under the DVD drive.
  4. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: 步骤 4 中的图像 1,1
    • - Carefully remove the cover, by unpopping it with a slim flathead, slide it out away from the RJ-45, HDMI and VGA ports.
  5. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: 步骤 5 中的图像 1,1
    • - The audio/usb interface card is now within reach. Just remove the two screws and carefully slide out the flat connector to remove the card.
  6. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: 步骤 6 中的图像 1,1
    • - Fire up the air compressor and blow out dust from the fan and heatsinks.
  7. Disassembling Sony Vaio VGN-FW 590 Audio USB Board: 步骤 7 中的图像 1,1
    • - If you are replacing your RAM, simply unpop the four latches and slide out the memory sticks.
结论
8等其他人完成本指南。
Artem Nikulkov
于10/22/10注册
313 声望
撰写一个指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 3
过去 7 天: 11
过去 30 天: 20
总计 21,103
