当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Unscrew the four Torx screws from the backplate.
The backplate may begin to separate from the keypad face. Do not try to remove it yet.
The screws are T5 Torx screws, 5.6mm.
Using the Spudger, gently pry up the U-shaped grey cover below the keypad.
The cover is secured with adhesive tape. The gentler this is removed, the easier it will be to reassemble.
Separate the keypad face from the backplate.
The keypad keys and the button component are both loose inside the phone, so take note of their orientation in case they become dislodged.
Take note of the braided cord's state. Upon reassembly it should be returned to the same orientation.
Holding the backplate away from the swivel, remove the 4 small Phillips screws and both stamped struts from the swivel assembly.
Note that only the bottom strut has a tab.
The screws are Phillips, 2.9mm
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
