跳转到主内容
Disassembling Sony Ericsson w600i Back Housing
你所需要的
  1. Disassembling Sony Ericsson w600i Back Housing, Disassembling Sony Ericsson w600i Battery Cover: 步骤 1 中的图像 1,1
    • Grip the lower portion of the back of the phone and slide downwards.
  2. Disassembling Sony Ericsson w600i Back Housing, Battery: 步骤 2 中的图像 1,1
    • Lift battery at the rounded notch near the bottom of the phone.
  3. Disassembling Sony Ericsson w600i Back Housing, Back housing: 步骤 3 中的图像 1,1
    • Unscrew the four Torx screws from the backplate.
    • The backplate may begin to separate from the keypad face. Do not try to remove it yet.
    • The screws are T5 Torx screws, 5.6mm.
  4. Disassembling Sony Ericsson w600i Back Housing: 步骤 4 中的图像 1,1
    • Swivel the phone open.
  5. Disassembling Sony Ericsson w600i Back Housing: 步骤 5 中的图像 1,1
    • Using the Spudger, gently pry up the U-shaped grey cover below the keypad.
    • The cover is secured with adhesive tape. The gentler this is removed, the easier it will be to reassemble.
  6. Disassembling Sony Ericsson w600i Back Housing: 步骤 6 中的图像 1,1
    • Remove the two Torx screws from below the cover.
    • These are T5 Torx screws, 8.6mm.
  7. Disassembling Sony Ericsson w600i Back Housing: 步骤 7 中的图像 1,1
    • Gently work a spudger or a fingernail between the keypad face and the backplate.
    • The pieces are clipped together most tightly at the bottom loop section.
  8. Disassembling Sony Ericsson w600i Back Housing: 步骤 8 中的图像 1,2 Disassembling Sony Ericsson w600i Back Housing: 步骤 8 中的图像 2,2
    • Separate the keypad face from the backplate.
    • The keypad keys and the button component are both loose inside the phone, so take note of their orientation in case they become dislodged.
    • Take note of the braided cord's state. Upon reassembly it should be returned to the same orientation.
  9. Disassembling Sony Ericsson w600i Back Housing: 步骤 9 中的图像 1,3 Disassembling Sony Ericsson w600i Back Housing: 步骤 9 中的图像 2,3 Disassembling Sony Ericsson w600i Back Housing: 步骤 9 中的图像 3,3
    • Holding the backplate away from the swivel, remove the 4 small Phillips screws and both stamped struts from the swivel assembly.
    • Note that only the bottom strut has a tab.
    • The screws are Phillips, 2.9mm
  10. Disassembling Sony Ericsson w600i Back Housing: 步骤 10 中的图像 1,1
    • The back housing is now disassembled, and the swivel assembly is revealed.
结论
Beau Blanchard
于09/30/12注册
20 声望
创作了6篇指南
团队
University of Maine, Team 1-5, Diaz Fall 2012 University of Maine, Team 1-5, Diaz Fall 2012 的会员
UMAINE-DIAZ-F12S1G5
1 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 429
