跳转到主内容
加入维修社区 - 创建账户
Disassembling Sony Ericsson W580i Back Cover
你所需要的
  1. Disassembling Sony Ericsson W580i Back Cover, Battery: 步骤 1 中的图像 1,3 Disassembling Sony Ericsson W580i Back Cover, Battery: 步骤 1 中的图像 2,3 Disassembling Sony Ericsson W580i Back Cover, Battery: 步骤 1 中的图像 3,3
    • Hold the phone with the screen facing down. Push the back cover firmly down and slide it towards you.
    • The panel will slide down about 2mm.
    • Lift the panel away from the phone.
  2. Disassembling Sony Ericsson W580i Back Cover: 步骤 2 中的图像 1,1
    • Lift the battery out from the bottom edge.
  3. Disassembling Sony Ericsson W580i Back Cover, Back Cover: 步骤 3 中的图像 1,1
    • Insert the edge of an opening tool between the back cover and the phone body on the top edge (not to be confused with the edge where the phone slides).
    • Pry the back case off of the phone working your way around the edges until the panel is freed from the phone.
    • Be careful when pulling the spudger down the side by the charging port. The plastic cover may bend or snap.
  4. Disassembling Sony Ericsson W580i Back Cover: 步骤 4 中的图像 1,3 Disassembling Sony Ericsson W580i Back Cover: 步骤 4 中的图像 2,3 Disassembling Sony Ericsson W580i Back Cover: 步骤 4 中的图像 3,3
    • While removing the back cover do not lose the power button. It is held in place by the back cover and may fall off during removal.
    • Pull the back cover away from the phone.
    • Remove the power button if it has not already come off.
结论
4等其他人完成本指南。
Cherie
于10/09/11注册
220 声望
创作了2篇指南
团队
Cal Poly, Team 5-31, Amido Fall 2011 Cal Poly, Team 5-31, Amido Fall 2011 的会员
CPSU-AMIDO-F11S5G31
4 名成员
创作了12篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 14
过去 30 天: 39
总计 9,184
