跳转到主内容
Disassembling Sony Ericsson QuickShare T630 Phone Enclosure
你所需要的
  1. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure, Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 1 中的图像 1,1
    • Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
  2. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 2 中的图像 1,2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 2 中的图像 2,2
    • Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
  3. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 3 中的图像 1,1
    • Slide the battery upward to remove.
  4. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 4 中的图像 1,2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 4 中的图像 2,2
    • Remove the rubber plug located near the camera by gently prying upward with your fingers.
    • Gently lift the camera shield after removal of the rubber plug.
  5. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 5 中的图像 1,2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 5 中的图像 2,2
    • Pry the remaining panel to loosen its contact to the phone using a spudger.
    • Slide the panel upward to remove it completely.
    • These steps will require a slight appliance of force.
  6. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 6 中的图像 1,1
    • Slide the aerial upward to remove it.
  7. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 7 中的图像 1,2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 7 中的图像 2,2
    • Remove the four screws located at each corner of the device.
  8. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 8 中的图像 1,2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 8 中的图像 2,2
    • Gently lift and remove the front panel of the phone after removing the screws.
  9. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 9 中的图像 1,3 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 9 中的图像 2,3 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 9 中的图像 3,3
    • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
    • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
    • Gently pull the ribbon from the circuit.
    • Remove the now disconnected screen.
  10. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 10 中的图像 1,3 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 10 中的图像 2,3 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: 步骤 10 中的图像 3,3
    • Remove the keyboard by slowly pulling it away from the circuit board.
    • There are no direct connections between the keyboard and phone.
    • These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
结论
2等其他人完成本指南。
Christine Becker
于10/28/13注册
101 声望
撰写一个指南
团队
University of Maine, Team 1-13, Diaz Fall 2013 University of Maine, Team 1-13, Diaz Fall 2013 的会员
UMAINE-DIAZ-F13S1G13
3 名成员
创作了14篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 5
总计 3,449
