跳转到主内容
Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display
你所需要的
  1. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display, Case: 步骤 1 中的图像 1,1
    • Begin by placing the camera upside down and removing the three small center screws.
    • All screws are the same size and length and can be used interchangably.
  2. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 步骤 2 中的图像 1,2 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 步骤 2 中的图像 2,2
    • Turn the camera on its side (Counterclockwise). Remove the two small screws on either side of the silver panel.
    • Turn the camera 180 degrees onto its other side and remove the two small screws on either side of the silver panel.
  3. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 步骤 3 中的图像 1,3 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 步骤 3 中的图像 2,3 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 步骤 3 中的图像 3,3
    • Locate the camera's tripod mount located on the bottom of the camera.
    • Carefully remove the camera's tripod mount and place it aside.
    • Be careful not to lose this piece.
    • Rotate the silver panel labeled 4x clockwise.
  4. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display, Separating Camera and Display: 步骤 4 中的图像 1,2 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display, Separating Camera and Display: 步骤 4 中的图像 2,2
    • Align the camera so that the side with "4x Optical Zoom" is facing toward you.
    • Gently twist the bottom corner clockwise until you feel the side panel unlock.
    • Lift off the side panel and set aside.
  5. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 步骤 5 中的图像 1,2 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 步骤 5 中的图像 2,2
    • Rotate the camera 180 degrees to face the side panel with the lanyard loop on it.
    • Gently lift the panel vertically until it lifts off
    • Take care to not lose the small rectangular portion on the bottom of the panel.
  6. Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 步骤 6 中的图像 1,3 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 步骤 6 中的图像 2,3 Disassembling Sony Cyber-shot DSC-W230 Separating Camera and Display: 步骤 6 中的图像 3,3
    • Position the camera so the bottom is facing up and the display away from the surface.
    • Gently pry the screen portion from the camera portion with your fingers or a plastic prybar.
    • Do not fully separate the two components! the screen is attached by two ribbon cables.
    • Lay the display flat to expose the circuit board and the display control ribbon cables.
结论
Steve Van Hall
于03/09/12注册
27 声望
创作了2篇指南
团队
Clemson, Team 2-3, Benson Spring 2012 Clemson, Team 2-3, Benson Spring 2012 的会员
CLEM-BENSON-S12S2G3
3 名成员
创作了11篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,686
