跳转到主内容
Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover
你所需要的
  1. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Battery: 步骤 1 中的图像 1,2 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Battery: 步骤 1 中的图像 2,2
    • Locate the battery door at the bottom of the camera.
    • Press down on the door and slide it back. The door will pop open.
  2. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: 步骤 2 中的图像 1,1
    • Remove the battery from the door that you opened in the previous step.
  3. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: 步骤 3 中的图像 1,3 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: 步骤 3 中的图像 2,3 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover, Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: 步骤 3 中的图像 3,3
    • There are two screws on the left and right sides of the camera, and two screws on the bottom.
    • Use a PH00 screwdriver and remove the six 2.9mm screws.
  4. Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: 步骤 4 中的图像 1,2 Disassembling Sony Cyber-shot DSC-T1 Removing Front Cover: 步骤 4 中的图像 2,2
    • Use hands to gently pry the front casing away from the camera.
结论
另外一个人完成了本指南。
iDeleted
于07/07/10注册
2,101 声望
创作了39篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 9
总计 2,543
