本指南有最近更改,您可查看未经巡查的最新版本。
简介
Before being able to access the inner parts of the device, it is necessary to remove the plastic outer case. This can easily be done in a few simple steps.
你所需要的
Begin by placing the camera flat against a surface and remove the nine (9) black screws. Each screw is of the same length and can be used interchangeably
Place the camera with the lens facing down. Use the phillips head screwdriver to remove the silver screw in the corner near the photo capture button.
Flip the camera over. Use the plastic opening tool to detach the black clip near the capture button.
Grasp the top cover and gently remove it from the camera body.
2等其他人完成本指南。
