跳转到主内容
加入维修社区 - 创建账户
Disassembling Sony Clie PEG-SL10
你所需要的
  1. Disassembling Sony Clie PEG-SL10, Disassembling Sony Clie PEG-SL10: 步骤 1 中的图像 1,1
    • Start by holding your Sony Clie PEG-SL10 face-up in your hand.
  2. Disassembling Sony Clie PEG-SL10: 步骤 2 中的图像 1,1
    • Turn over your Sony Clie and unlock the cover slide lock.
  3. Disassembling Sony Clie PEG-SL10: 步骤 3 中的图像 1,1
    • After unlocking the cover slide lock, remove the cover and set aside.
  4. Disassembling Sony Clie PEG-SL10: 步骤 4 中的图像 1,1
    • Turn your Sony Clie face-up.
    • Using a Phillips #0 screwdriver, remove the six case screws on the sides and bottom of the device.
  5. Disassembling Sony Clie PEG-SL10: 步骤 5 中的图像 1,1
    • Remove the front case by gently lifting away from the device.
  6. Disassembling Sony Clie PEG-SL10: 步骤 6 中的图像 1,1
    • Turn the Sony Clie face down and open the back case by prying open the left side of the device.
    • It will open like a book connected by hinges on the right side.
  7. Disassembling Sony Clie PEG-SL10: 步骤 7 中的图像 1,1
    • Gently pry off the right side off the back panel and set it aside, leaving room for the scroll wheel at the upper right corner.
  8. Disassembling Sony Clie PEG-SL10: 步骤 8 中的图像 1,1
    • Using a Phillips #0 screwdriver, remove the two screws holding the scroll wheel in place.
  9. Disassembling Sony Clie PEG-SL10: 步骤 9 中的图像 1,1
    • Pull out both sides of the clip to remove the scroll wheel power cable from the device.
  10. Disassembling Sony Clie PEG-SL10: 步骤 10 中的图像 1,1
    • Using a Phillips #0 screwdriver, unscrew the two screws towards the bottom sides of the Sony Clie to remove the battery harness.
  11. Disassembling Sony Clie PEG-SL10: 步骤 11 中的图像 1,1
    • Pull the power cable from the socket located above the upper right side of the battery harness.
  12. Disassembling Sony Clie PEG-SL10: 步骤 12 中的图像 1,1
    • Gently pull out the clips to remove the bottom power cables from the motherboard after removing the battery harness.
  13. Disassembling Sony Clie PEG-SL10: 步骤 13 中的图像 1,1
    • Rotate the motherboard 180 degrees so that it is upside down facing toward you to expose the power cables on the other side.
  14. Disassembling Sony Clie PEG-SL10: 步骤 14 中的图像 1,1
    • Gently pull out the clips to remove the top power cables from the motherboard.
结论
附加文件
Steve
于10/18/11注册
9 声望
撰写一个指南
团队
James Madison, Team 1-4, Allen Fall 2011 James Madison, Team 1-4, Allen Fall 2011 的会员
JMU-ALLEN-F11S1G4
3 名成员
创作了4篇指南
0指南评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 31
总计 2,111
