跳转到主内容
Disassembling Sony Clie PEG-NR70 The Case
你所需要的
  1. Disassembling Sony Clie PEG-NR70 The Case, The Case: 步骤 1 中的图像 1,1
    • Unscrew the 1.9mm screw located at the top of the device with a Phillips #00 screwdriver.
    • It may be helpful to set up a piece of paper to keep track of where removed screws came from.
  2. Disassembling Sony Clie PEG-NR70 The Case: 步骤 2 中的图像 1,1
    • Unscrew the 2.5mm screw located on the left side of the device with a Phillips #00 screwdriver.
  3. Disassembling Sony Clie PEG-NR70 The Case: 步骤 3 中的图像 1,2 Disassembling Sony Clie PEG-NR70 The Case: 步骤 3 中的图像 2,2
    • Unscrew the five 2.5mm screws on the back panel with a Phillips #00 screwdriver.
    • Remove the back panel by lifting it away with your hands.
结论
另外一个人完成了本指南。
Daniel Soski
于04/18/13注册
57 声望
创作了6篇指南
团队
Cal Poly, Team 14-11, Maness Spring 2013 Cal Poly, Team 14-11, Maness Spring 2013 的会员
CPSU-MANESS-S13S14G11
5 名成员
创作了8篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 7
总计 650
