跳转到主内容
Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing
你所需要的
  1. Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing, Batteries: 步骤 1 中的图像 1,1
    • Press down on the two tabs at the top of the door.
    • Rotate the door away from the radio, towards you.
    • Lift the door out of the three smaller tabs on the bottom.
    • Ensure the radio is turned off to avoid the possibility of electric shock.
    • The battery compartment door is not shown.
  2. Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing, Batteries: 步骤 2 中的图像 1,3 Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing, Batteries: 步骤 2 中的图像 2,3 Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing, Batteries: 步骤 2 中的图像 3,3
    • Push the batteries against the spring and pull out using your finger to remove them.
    • To insert the new batteries, push the negative end of the 1st battery against a spring and follow the diagram pictured to insert the batteries in the correct orientation.
  3. Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing, Screws: 步骤 3 中的图像 1,3 Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing, Screws: 步骤 3 中的图像 2,3 Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing, Screws: 步骤 3 中的图像 3,3
    • Remove the 6 screws (30 mm in length) with the Phillips #2 Screwdriver from the large holes marked by arrows on the radio.
  4. Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing, Opening: 步骤 4 中的图像 1,1
    • Press the EJECT button to open the cassette deck.
    • Pressing this button is required to allow the front face to separate from the case.
  5. Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing: 步骤 5 中的图像 1,2 Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing: 步骤 5 中的图像 2,2
    • Grasp the radio from the front and back halves and gently pull apart to separate them.
  6. Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing: 步骤 6 中的图像 1,2 Disassembling Sony CFS-204 Radio Cassette-Corder Outer Casing: 步骤 6 中的图像 2,2
    • Pull the white plug out from the red outlet in the Orange circuit board in the back face of the casing.
    • Take care not to break the red outlet off the circuit board.
    • The front and back portions of the casing are now separated from each other.
结论
4等其他人完成本指南。
一条评论
Trying to do this with the CFS-202, a previous generation. Silly Q from a novice, any recommends on what screwdriver to get for this? The long chasm makes it difficult to get to the screws. Thanks!
Michael C - 回复
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 18
过去 30 天: 44
总计 3,800
