跳转到主内容
Disassembling Sony Action Cam HDR-AS15 Circuit Board
你所需要的
  1. Disassembling Sony Action Cam HDR-AS15 Circuit Board, Battery: 步骤 1 中的图像 1,1
    • To access the battery, gently pry open the rear cover of the action cam.
  2. Disassembling Sony Action Cam HDR-AS15 Circuit Board: 步骤 2 中的图像 1,2 Disassembling Sony Action Cam HDR-AS15 Circuit Board: 步骤 2 中的图像 2,2
    在这个步骤中使用的工具:
    购买
    • Using a pair of tweezers, firmly grip the protrusion where the PULL signifies and remove the tray and battery.
  3. Disassembling Sony Action Cam HDR-AS15 Circuit Board, Disassembling Sony Action Cam HDR-AS15 Circuit Board: 步骤 3 中的图像 1,3 Disassembling Sony Action Cam HDR-AS15 Circuit Board, Disassembling Sony Action Cam HDR-AS15 Circuit Board: 步骤 3 中的图像 2,3 Disassembling Sony Action Cam HDR-AS15 Circuit Board, Disassembling Sony Action Cam HDR-AS15 Circuit Board: 步骤 3 中的图像 3,3
    • Open the bottom tab with your finger or a plastic opening tool.
    • Pull the tab out, not up, to remove it completely.
    • Remove the two screws from the device.
    • Use your fingers to remove the plastic plate.
  4. Disassembling Sony Action Cam HDR-AS15 Circuit Board: 步骤 4 中的图像 1,1
    • Separate the outer casing from the electronics by pushing on one of the ports toward the back end of the case. The electronics should slide right out.
  5. Disassembling Sony Action Cam HDR-AS15 Circuit Board: 步骤 5 中的图像 1,2 Disassembling Sony Action Cam HDR-AS15 Circuit Board: 步骤 5 中的图像 2,2
    • Remove the two 6.4 mm screws on the LCD side of the device using a Phillips #00 screwdriver.
    • Flip the LCD display downward to reveal the circuit board.
结论
3等其他人完成本指南。
团队
USF Tampa, Team 1-2, Sullivan Winter 2015 USF Tampa, Team 1-2, Sullivan Winter 2015 的会员
USFT-SULLIVAN-W15S1G2
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 1,655
