跳转到主内容
Disassembling Sirius Stiletto 100 Internal Antenna
你所需要的
  1. Disassembling Sirius Stiletto 100 Internal Antenna, Front Cover: 步骤 1 中的图像 1,2 Disassembling Sirius Stiletto 100 Internal Antenna, Front Cover: 步骤 1 中的图像 2,2
    • Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
  2. Disassembling Sirius Stiletto 100 Internal Antenna: 步骤 2 中的图像 1,2 Disassembling Sirius Stiletto 100 Internal Antenna: 步骤 2 中的图像 2,2
    • Use a Philip's head screw driver to remove the screws from the case.
    • Place the screws in a small container to avoid losing them.
  3. Disassembling Sirius Stiletto 100 Internal Antenna: 步骤 3 中的图像 1,3 Disassembling Sirius Stiletto 100 Internal Antenna: 步骤 3 中的图像 2,3 Disassembling Sirius Stiletto 100 Internal Antenna: 步骤 3 中的图像 3,3
    • Remove the front cover.
    • First, insert a small pry bar where the black front cover and white back cover meet.
    • Begin prying the black plastic up, slowing moving around to the bottom and other side.
    • At an angle, carefully pull up on the front cover separate the two pieces.
    • Excellent! Now you have removed the front cover!
  4. Disassembling Sirius Stiletto 100 Internal Antenna, Circuit Board: 步骤 4 中的图像 1,1
    • While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
  5. Disassembling Sirius Stiletto 100 Internal Antenna: 步骤 5 中的图像 1,2 Disassembling Sirius Stiletto 100 Internal Antenna: 步骤 5 中的图像 2,2
    • Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover.
  6. Disassembling Sirius Stiletto 100 Internal Antenna: 步骤 6 中的图像 1,1
    • Congratulations! You have successfully removed the internal circuit board from the Sirius Stiletto 100 back cover.
  7. Disassembling Sirius Stiletto 100 Internal Antenna, Internal Antenna: 步骤 7 中的图像 1,3 Disassembling Sirius Stiletto 100 Internal Antenna, Internal Antenna: 步骤 7 中的图像 2,3 Disassembling Sirius Stiletto 100 Internal Antenna, Internal Antenna: 步骤 7 中的图像 3,3
    • Flip the circuit board over to look at the back side, so that LCD screen is facing away from you.
    • Use a Phillip's head screwdriver to remove the screw from the back of the internal antenna.
  8. Disassembling Sirius Stiletto 100 Internal Antenna: 步骤 8 中的图像 1,2 Disassembling Sirius Stiletto 100 Internal Antenna: 步骤 8 中的图像 2,2
    • Use your fingers to pry the internal antenna off of the circuit board. You may need to wiggle it back and forth to successfully remove it.
    • Woohoo! You have removed the internal antenna!
结论
另外一个人完成了本指南。
Trey
于03/09/12注册
80 声望
创作了2篇指南
团队
Clemson, Team 2-1, Benson Spring 2012 Clemson, Team 2-1, Benson Spring 2012 的会员
CLEM-BENSON-S12S2G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 2,806
