跳转到主内容
Disassembling Sirius Stiletto 100 Circuit Board
你所需要的
  1. Disassembling Sirius Stiletto 100 Circuit Board, Front Cover: 步骤 1 中的图像 1,2 Disassembling Sirius Stiletto 100 Circuit Board, Front Cover: 步骤 1 中的图像 2,2
    • Remove the battery (which also functions as the back cover) from the device. This step is not explicitly shown, but a picture without the battery cover shows the device post-battery removal.
  2. Disassembling Sirius Stiletto 100 Circuit Board: 步骤 2 中的图像 1,2 Disassembling Sirius Stiletto 100 Circuit Board: 步骤 2 中的图像 2,2
    • Use a Philip's head screw driver to remove the screws from the case.
    • Place the screws in a small container to avoid losing them.
  3. Disassembling Sirius Stiletto 100 Circuit Board: 步骤 3 中的图像 1,3 Disassembling Sirius Stiletto 100 Circuit Board: 步骤 3 中的图像 2,3 Disassembling Sirius Stiletto 100 Circuit Board: 步骤 3 中的图像 3,3
    • Remove the front cover.
    • First, insert a small pry bar where the black front cover and white back cover meet.
    • Begin prying the black plastic up, slowing moving around to the bottom and other side.
    • At an angle, carefully pull up on the front cover separate the two pieces.
    • Excellent! Now you have removed the front cover!
  4. Disassembling Sirius Stiletto 100 Circuit Board, Circuit Board: 步骤 4 中的图像 1,1
    • While looking down at the device, place your index finger at the top of the circuit board and your thumb on the device screen.
  5. Disassembling Sirius Stiletto 100 Circuit Board: 步骤 5 中的图像 1,2 Disassembling Sirius Stiletto 100 Circuit Board: 步骤 5 中的图像 2,2
    • Using your fingers, gently pull the top of the circuit board up toward you while also sliding the bottom of the circuit board away from the bottom of the Sirius Stiletto 100 back cover.
  6. Disassembling Sirius Stiletto 100 Circuit Board: 步骤 6 中的图像 1,1
    • Congratulations! You have successfully removed the internal circuit board from the Sirius Stiletto 100 back cover.
结论
2等其他人完成本指南。
Staten
于03/09/12注册
69 声望
撰写一个指南
团队
Clemson, Team 2-1, Benson Spring 2012 Clemson, Team 2-1, Benson Spring 2012 的会员
CLEM-BENSON-S12S2G1
3 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 12
总计 1,927
