跳转到主内容
Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing
你所需要的
  1. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing, Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: 步骤 1 中的图像 1,1
    • Camera lens are delicate and intricate. Be careful with the disassembly and work slowly.
    • Take the lens away from camera
    • DO NOT FORGET: THAT YOU ARE DOING ALL ON YOUR OWN RESPONSIBILITY
  2. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: 步骤 2 中的图像 1,2 Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: 步骤 2 中的图像 2,2
    • Unscrew the top part and detach it.
    • Unjoin cables. Be careful; they're delicate, and easily torn.
    • Try to avoid touching sensitive electronic components.
    • Unfasten the screws that hold the circuit board in place, and separate it from the rest of the lens assembly.
  3. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: 步骤 3 中的图像 1,2 Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: 步骤 3 中的图像 2,2
    • Take away zoom rubber and you will find srews
  4. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: 步骤 4 中的图像 1,2 Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: 步骤 4 中的图像 2,2
    • Keep unscrewing and removing the parts until you reach what you need to fix.
    • Zoom bearing can be taken away by unscrewing its srews.
  5. Disassembling Sigma 24-70mm F2.8 EX DG Macro Lens Zoom bearing: 步骤 5 中的图像 1,1
    • Here is one of the parts which was broken, so I go to camera repair shop, and bought that parts. As this was not the only part broken, I had to leave for additional repair.
    • When you finish you can put all back together
结论
6等其他人完成本指南。
Rimvydas
于03/29/12注册
718 声望
创作了2篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 11
过去 30 天: 57
总计 30,163
