跳转到主内容
Disassembling Siemens A56 Motherboard Metal Frame
你所需要的
  1. Disassembling Siemens A56 Motherboard Metal Frame, Front Plate: 步骤 1 中的图像 1,3 Disassembling Siemens A56 Motherboard Metal Frame, Front Plate: 步骤 1 中的图像 2,3 Disassembling Siemens A56 Motherboard Metal Frame, Front Plate: 步骤 1 中的图像 3,3
    • Firmly grasp the white casing of the phone with one hand and the blue cover with the other hand as seen in the first picture.
    • Pull up on the two plastic clips at the top of the phone.
    • While the clips are pulled up, pull the blue cover away from the white casing to remove it.
  2. Disassembling Siemens A56 Motherboard Metal Frame, Back Plastic Cover: 步骤 2 中的图像 1,3 Disassembling Siemens A56 Motherboard Metal Frame, Back Plastic Cover: 步骤 2 中的图像 2,3 Disassembling Siemens A56 Motherboard Metal Frame, Back Plastic Cover: 步骤 2 中的图像 3,3
    • Along the side of the metal frame of the phone, locate the six screws.
    • Using a T5 screwdriver bit, unscrew the six 1/4 inch screws and store them in a safe place.
    • The screws are very small and can strip easily, so proper care is required when removing and storing the screws.
  3. Disassembling Siemens A56 Motherboard Metal Frame: 步骤 3 中的图像 1,3 Disassembling Siemens A56 Motherboard Metal Frame: 步骤 3 中的图像 2,3 Disassembling Siemens A56 Motherboard Metal Frame: 步骤 3 中的图像 3,3
    • To remove the back plastic cover, grasp the device with both hands as seen in the first picture.
    • Gently remove the motherboard from the back plastic cover.
    • The motherboard is fragile, so proper care is necessary when handling and storing in order to prevent damage.
  4. Disassembling Siemens A56 Motherboard Metal Frame, Motherboard Metal Frame: 步骤 4 中的图像 1,3 Disassembling Siemens A56 Motherboard Metal Frame, Motherboard Metal Frame: 步骤 4 中的图像 2,3 Disassembling Siemens A56 Motherboard Metal Frame, Motherboard Metal Frame: 步骤 4 中的图像 3,3
    • Turn over the keypad interface and using the blue plastic opening tool, gently pry the bottom of the metal frame.
    • Once loosened, the metal frame should be able to be lifted from the motherboard.
结论
Joseph Casey
于03/26/14注册
409 声望
创作了4篇指南
团队
Clemson, Team 6-6, Benson Spring 2014 Clemson, Team 6-6, Benson Spring 2014 的会员
CLEM-BENSON-S14S6G6
4 名成员
创作了18篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 11
过去 30 天: 13
总计 170
