跳转到主内容
Disassembling Sidekick Q700 Phone Sidekick Q700 Phone
已存档的指南
本指南只作为历史记录保留。请使用指南的最新版本来进行维修。
你所需要的
  1. Disassembling Sidekick Q700 Phone Sidekick Q700 Phone, Phone: 步骤 1 中的图像 1,1
    • On the back of the device unscrew the top right, top left, bottom right, and bottom left buttons using appropriate size Phillips screwdriver.
  2. Disassembling Sidekick Q700 Phone Sidekick Q700 Phone: 步骤 2 中的图像 1,1
    • Once screws are dismantled, use plastic opening tool to assist separation of the top half of device from the bottom half.
  3. Disassembling Sidekick Q700 Phone Sidekick Q700 Phone: 步骤 3 中的图像 1,1
    • Unscrew the screws around the keypad and take apart slowly and gently using your hands.
  4. Disassembling Sidekick Q700 Phone Sidekick Q700 Phone: 步骤 4 中的图像 1,1
    • Use the plastic opening tool to pry the protective screen off the main part off the screen.
  5. Disassembling Sidekick Q700 Phone Sidekick Q700 Phone: 步骤 5 中的图像 1,1
    • Remove the individual green and yellow technical pieces from the back of the phone.
  6. Disassembling Sidekick Q700 Phone Sidekick Q700 Phone: 步骤 6 中的图像 1,1
    • Remove the battery
  7. Disassembling Sidekick Q700 Phone Sidekick Q700 Phone: 步骤 7 中的图像 1,1
    • You have all the pieces separated.
  8. Disassembling Sidekick Q700 Phone Sidekick Q700 Phone: 步骤 8 中的图像 1,1
    • Tools Used.
结论
Rich
于04/08/13注册
125 声望
创作了6篇指南
团队
SUNY Cortland, Team 1-4, Getto Spring 2013 SUNY Cortland, Team 1-4, Getto Spring 2013 的会员
SUNYCORT-GETTO-S13S1G4
4 名成员
创作了6篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 114
