当前版本的文档还未经巡查,您可以查看最新的已查核版本。
Turn the camera off by pressing the small, square button embedded in the top rim of the camera.
Locate the battery hatch on the bottom-right side of the camera and slide it outwards to open.
In the compartment, move the small notch and push down on the battery to remove it.
During reassembly, there is an arrow on the battery hatch indicating which way it goes in.
Using the spudger, gently pry the rear panel away from the left side.
Be careful not to damage the three green cables as you remove the rear panel of the camera.
Using the Phillips #00 screwdriver, remove the eight black screws connecting the green keypad chip to the rear panel.
Do not put any excessive force on the green wires.
Using the Phillips #00 screwdriver, remove the 3 screws located across the top of the camera.
Separate the black plastic panel from the camera. The camera button will be attached, so be gentle.
Using the spudger, gently lift off the front cover of the camera.
The front cover is fragile, so be gentle when removing it. It can easily break if not removed carefully.
嵌入本指南
选择一个尺寸并复制下面的代码,将本指南作为一个小插件嵌入到你的网站/论坛中。
预览
