跳转到主内容
Disassembling Sanyo SCP-8100 Back Panel
你所需要的
  1. Disassembling Sanyo SCP-8100 Back Panel, Battery: 步骤 1 中的图像 1,3 Disassembling Sanyo SCP-8100 Back Panel, Battery: 步骤 1 中的图像 2,3 Disassembling Sanyo SCP-8100 Back Panel, Battery: 步骤 1 中的图像 3,3
    • Push and hold the button on the back toward the direction of the arrow to unlock the battery.
    • Lift and remove the battery from the back of the phone.
  2. Disassembling Sanyo SCP-8100 Back Panel, Back Panel: 步骤 2 中的图像 1,2 Disassembling Sanyo SCP-8100 Back Panel, Back Panel: 步骤 2 中的图像 2,2
    • Using a push pin, pull out the plug on the back, located under the antenna.
    • You may try to use a spudger or opening tool, however, you may damage the plug because those tools are too thick.
  3. Disassembling Sanyo SCP-8100 Back Panel: 步骤 3 中的图像 1,1
    • Unscrew the four 6mm long screws with a Tri-Wing Y1 screwdriver.
  4. Disassembling Sanyo SCP-8100 Back Panel: 步骤 4 中的图像 1,2 Disassembling Sanyo SCP-8100 Back Panel: 步骤 4 中的图像 2,2
    • Use a plastic opening tool to pry the back panel along the edges.
    • You may need to apply some force when prying.
  5. Disassembling Sanyo SCP-8100 Back Panel: 步骤 5 中的图像 1,3 Disassembling Sanyo SCP-8100 Back Panel: 步骤 5 中的图像 2,3 Disassembling Sanyo SCP-8100 Back Panel: 步骤 5 中的图像 3,3
    • While removing the back panel, take out the rubber cover on each side.
结论
Yemane
于04/13/13注册
11 声望
撰写一个指南
团队
Cal Poly, Team 10-41, Amido Spring 2013 Cal Poly, Team 10-41, Amido Spring 2013 的会员
CPSU-AMIDO-S13S10G41
4 名成员
创作了12篇指南
0条评论
添加评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 10
总计 366
