跳转到主内容
修复你的物品
维修的权力
配件 & 工具
  1. Remove the 2 screws on the back cover using a Phillips head #0 screwdriver. Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  3. Remove the screw on each side of the device using a Phillips head screwdriver. Remove the screw on each side of the device using a Phillips head screwdriver.
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  4. Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws. Gently pry open the back cover. Insert the plastic opening tool in between the cover joints. Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
结论
另外一个人完成了本指南。
Dylan Peters
于2013年10月18日注册
409 信誉积分
创作了4篇指南
团队
Clemson, Team 14-8, Benson Fall 2013 Clemson, Team 14-8, Benson Fall 2013 的会员
CLEM-BENSON-F13S14G8
3 名成员
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 258
