跳转到主内容
修复你的物品
维修的权力
配件 & 工具
  1. Remove the 2 screws on the back cover using a Phillips head #0 screwdriver. Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
    • Remove the 2 screws on the back cover using a Phillips head #0 screwdriver.
  2. Remove the screw on each side of the device using a Phillips head screwdriver. Remove the screw on each side of the device using a Phillips head screwdriver.
    • Remove the screw on each side of the device using a Phillips head screwdriver.
  3. Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws. Gently pry open the back cover. Insert the plastic opening tool in between the cover joints. Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
    • Using the plastic opening kit, place the prying end of the kit into the opening created by removing the screws.
    • Gently pry open the back cover. Insert the plastic opening tool in between the cover joints.
  4. 任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
    任天堂 Switch 套装
    快速恢复到游戏的状态
    购买 Switch 套装
  5. Using the philips screwdriver, remove the two screws on the mother board. Using the philips screwdriver, remove the two screws on the mother board.
    • Using the philips screwdriver, remove the two screws on the mother board.
  6. Place the pry tool in-between the front cover and mother board. Gently separate the front cover. Gently separate the front cover.
    • Place the pry tool in-between the front cover and mother board.
    • Gently separate the front cover.
  7. After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
    • After opening the front cover you will see and electric ribbon connecting the buttons to the mother board.
  8. CAUTION: Do not rip the electric ribbon from the mother board. Carefully flip up the plastic lip that holds the electric ribbon to the board.
    • CAUTION: Do not rip the electric ribbon from the mother board.
    • Carefully flip up the plastic lip that holds the electric ribbon to the board.
结论
另外一个人完成了本指南。
Jason Farr
于2013年10月21日注册
353 信誉积分
创作了3篇指南
团队
Clemson, Team 14-8, Benson Fall 2013 Clemson, Team 14-8, Benson Fall 2013 的会员
CLEM-BENSON-F13S14G8
3 名成员
创作了7篇指南
添加评论
浏览统计数据:
过去的24小时: 0
过去的7天: 0
过去的30天: 0
总计 158
